Both fog lights not working at the same time F150 2018 5.0 any advice?
Old Jan 16, 2021 | 11:55 AM
GladiatorF150's Avatar
Default Both fog lights not working at the same time F150 2018 5.0 any advice?
I was driving last night and i had really hard time seeing where I’m going with the horrible head lights so i decided to turn on the fog lights, the fog light indicator is on the meter panel is on but nothing happened. When i arrived i realized that both fog lights is not turning on at all.
anyone has the same issue, i don’t think it’s a bulb failure because it’s both of bulbs and i was looking to find if there is any fuse for the fog lights in the owner’s manual and there is nothing.
Old Jan 16, 2021 | 12:14 PM
Until you do some checking, speculating can get costly and not do too much.
I have seen instances where both lamps were burned out and that doesn't happen very often.so the better thing to do is confirm power is getting to the lamps, right at the lamps themselves. Once that is known, we go from there.
Old Jan 16, 2021 | 03:54 PM
Use Common Sense's Avatar
Concur on what HANKY said. Go the easy trouble shooting route. I had both high beams go out on me one time on our Freestar. Turned the high beams on one night going to work and within a few seconds of going on "POOF", both went out at the same time. Replaced the bulbs and never had an issue for years after replacing the bulbs. Since I worked 0000-0800, my lights spent most of their life on HIGH.
Old Jan 16, 2021 | 05:26 PM
Hi "Use Common Sense,",
Glad to see you are back helping us out.
Old Jan 19, 2021 | 03:46 PM
Thank you, Will definitely do the test this weekend.
mikewilder
Mar 14, 2020 05:19 AM
golem
Apr 19, 2013 09:20 PM
cougar281
Jan 4, 2009 01:22 AM
95 Ranger
Sep 11, 2006 03:09 PM
steveR
Aug 6, 2006 05:12 PM
