Brakes "pulsing" and rough ride 2018 F-150 (11k mi)
Old May 8, 2019 | 07:53 AM
wartrace's Avatar
Default Brakes "pulsing" and rough ride 2018 F-150 (11k mi)
Hi,
I have a 2018 F-150 with 11,000 miles on it. In the past few months I have noticed my brakes feel like they're sort of "pulsing" as in they are not fully braking. It isn't like when the anti-lock brake engages but more like stuttering. (It's hard to explain) Also I have noticed that I am feeling every bump in the road. The tire pressure is the same as when it was new.
Is this normal for Fords? I would appreciate any opinions before I bring it to the dealer so they don't "blow me off" saying "it's normal" when in fact it might not be.
Old May 9, 2019 | 02:29 AM
Don't be offended by my next question because it is important to know.
Do you drive with two feet on the pedals, one on the gas and one on the brake pedal?
Old May 9, 2019 | 05:00 AM
wartrace's Avatar
Smile
No, I never ride the brake as I live in a rural area with little to no traffic. As a matter of fact I tend to set my cruise control on the way into town. (Good question though)
Old May 9, 2019 | 08:35 AM
The sensation is felt in the peddle, any indication in the wheel on braking?
Factory tire inflation was generally on the low scale of the tire specs for a softer ride. What’s the pressure?
Old May 9, 2019 | 08:53 AM
wartrace's Avatar
Nothing felt via the steering wheel, just the pedal. The last time I checked the tire pressure it was at 38 psi.
BTW- I have put the truck in neutral to verify it wasn't the transmission. I still feel all the bumps in the road. I do not feel them at higher speeds (over 45mph)
Old May 10, 2019 | 04:17 AM
It seems we are chasing down 2 different problems.
One is the pulsing in the brake pedal when making a brake application
The other is a ride quality issue where you feel every bump in the road . With the ride quality issue do you also feel that on the brake pedal or just in the seat?
Do you know if your vehicle engine is turbocharged? If it is an Eco-boost, it should be.
One last question, who has been doing the oil changes on your vehicle? There is a very special reason for the oil question and it concerns turbo charged vehicles and LSPI (Low speed pre-ignition).
Old May 10, 2019 | 04:48 AM
wartrace's Avatar
I feel the ride quality issue in the seat. It is very minor and I am comparing the ride to my previous vehicle on the same stretch of road. It just seems like I feel it more in this truck. It is an eco-boost engine and I have done one oil change myself and the second was done at the dealer.
I did one of the oil changes myself and the second was done by the dealer. It is an eco-boost engine.
Old Oct 18, 2019 | 09:13 AM
wartrace's Avatar
I forgot I had posted this problem but wanted to let everyone know what the outcome was. I took it to the dealer and they told me the front driver strut was bad and all four brake rotors needed to be replaced. It was all under warranty so no out of pocket for me. The service writer told me they had never seen this problem (four bad rotors) before.
Old Oct 18, 2019 | 12:33 PM
Thank you for the update.
Wish we could see the warranty explanation on this one !
As always , anything is possible .
Old Oct 18, 2019 | 12:36 PM
wartrace's Avatar
I was pleased to have the rotors replaced under warranty after seeing so many people say they aren't covered. It was a relief.
renegaderob18
Mar 13, 2012 07:57 PM
Nifty50
Nov 16, 2011 02:40 PM
1984F250Man
Apr 17, 2011 10:11 AM
sobayimage
Feb 5, 2010 04:05 PM
techmanbd
Nov 26, 2005 02:04 PM
