engine hard to turn
Old Feb 16, 2013 | 12:35 PM
benenuf's Avatar
Default engine hard to turn
my 97 f150 173000 mls wont start.drove to a meeting there for 3hrs came out wont start thought was starter check starter found to be good tried to bar engine over with breaker bar and could turn engine but was extremly tight anyone had this problem with the 4.6.is this a common problem happening with engine and what is happening with engine.please help forum family.
Old Feb 16, 2013 | 01:37 PM
primem's Avatar
is it a no crank or cranks but won't start?
oil level is ok?
Old Mar 1, 2013 | 10:27 AM
benenuf's Avatar
No crank and oil level full only 1000 miles from last oil change 5w30
Old Mar 1, 2013 | 05:47 PM
primem's Avatar
The starter solenoid is clicking right? How did you rule out the starter. Any theft lights on?
Ideally, for any starting problem you should rule out the battery first.
I don't want you to get ahead of yourself. If you have hand cranked alot of engines over and know what a tight enging feels like proceed in that direction. If your not sure what tight is, lets start from the beginning.
if your sure its tight, the battery and starter are good and no theft lights are on...remove all the plugs, pull the fuel pump fuse, disconnect the coil connectors and see if it cranks over....maybe its hydrolocked?
the only time i had a seized engine...i had someone turn the key to start while I was checking power to the starter solenoid. The starter actually puffed smoke. When i hand cranked the crankpulley bolt with my breaker bar i couldn't even budge it.
Glowbug
Jan 28, 2022 12:43 PM
mccutcheon1988
Dec 13, 2008 08:36 PM
slow450
Dec 5, 2007 11:28 PM
Alcholic9000
Aug 21, 2007 11:24 AM
