Front Brake problem 2011 F-150
Old Jul 16, 2020 | 06:27 AM
  #11
Something to think about,
If in the process of replacing the caliper, air got into the ABS module /line, As it gets warm and expands it will apply pressure on that caliper. As suggested opening the bleeder on the caliper will allow the pressure to drop and free up the pads , if that is the problem.
You may need a scan tool to open the apply and dump solenoids in the ABS unit to correct this.
Brake systems are much different today from the older systems.
Old Sep 7, 2024 | 10:14 PM
  #12
mullins7472's Avatar
Hi, I am new here so might be in wrong place.Trying to find the t
Trans drain plug size(example M12-1.75 0r M14-1.50) for my 2020 ford edge with 8f35 trans. Thanks for the help,Charles
Old Sep 8, 2024 | 01:47 AM
  #13
Can we ask what happened that you need another plug ?
Many times there is an incomplete diagnosis and it is important to know all the info.
Old Sep 8, 2024 | 12:23 PM
  #14
Want to add a shut off drain valve when I change the fluid. Need to know the drain plug size so I can get the correct valve before I drain the fluid and refill.
Omar OneDouble Martinez
Jan 31, 2022 06:20 AM
coloradoyooper
Mar 27, 2011 08:01 PM
jeremyjudd
Dec 21, 2007 02:15 PM
91explorer12323
Apr 29, 2007 04:00 AM
techmanbd
Nov 26, 2005 02:04 PM
