fuse block terminals
Old Sep 10, 2020 | 09:30 AM
rustystud's Avatar
Thumbs down fuse block terminals
does anyone know what the terminals are called that extend the bottom connection of the wire to the fuse holder ,in the fuse block
restoring 1999 f150 and need to add a couple fuses >Wire are in their but no coupling to hold fuse
is this something available or is this a junk yard pick
thanks
Old Sep 13, 2020 | 07:04 AM
If course the first question is, what are you planning to add and how much current will the additions require.
Where the wiring will be and go is also a consideration. Sometimes you can tap into a hot feed and connect addl fuses to supply and protect what you are planning to install.
Sometimes not all fuse positions are actually used and you might be able to take advantage of those. You need to be careful that you don't overload the supply however.
The right way to do this is to know what the requirements are and go from there.
Last note of caution,,,,,,,,Fords, especially late models, do not like add ons, keep that in mind.
super6
Aug 10, 2019 12:55 PM
Davemac8776
Jan 16, 2017 03:40 AM
mbenson1
Jul 11, 2012 09:16 PM
big bopper
Dec 17, 2008 12:23 AM
jryan11518
Nov 11, 2006 02:00 AM
