Heat/Air Conditioner Setting Knob
Old Sep 24, 2010 | 12:45 PM
Biscuit's Avatar
Default Heat/Air Conditioner Setting ****
The **** to regulate the fan for heat and air conditioning only works at full blast now. I need to replace the switch but wonder if anyone has advice on how to remove the **** without causing damage.
Old Oct 9, 2010 | 12:31 PM
dtdano's Avatar
Kind of late since you posted awhile ago, but the **** just pulls off. You have to wiggle it a bit, but it will come off.
Old Nov 1, 2010 | 03:52 PM
Before you go replacing the switch, check the resistor body . That is in the circuit for all speeds except hi which is controlled by a separate relay.
JDMAN1
Oct 9, 2023 06:50 AM
Bobmoterhome
Jul 21, 2011 07:26 PM
renech
Sep 19, 2006 11:36 PM
thfrederick
May 13, 2006 04:43 PM
JDMAN1
Jun 8, 2005 11:51 PM
