hidden pcv 2002 f150 4.2
Old Dec 28, 2018 | 03:17 PM
retfirefighter's Avatar
Default hidden pcv 2002 f150 4.2
Ok where can I find the pcv valve on a 4.2 2002 please do not answer on the valve covers they are NOT their! Found the egr solenoid but not the pcv. F150 2002 with the 4.2 .
Old Dec 28, 2018 | 04:01 PM
It should be located on the pass side of the engine , to the rear of the coil pack with 2 coolant hoses connected to it the coolant pipe is what holds it in place.
Old Dec 28, 2018 | 04:25 PM
Thanks will take a look. Hinting all over for it for a week
Old Dec 28, 2018 | 04:35 PM
good try thats the heater core. Who wants to try next?
Old Dec 28, 2018 | 04:43 PM
got this from another site. if you follow the tube coming from the passenger side valve cover to where it plugs into the intake I believe thats where you will find the pcv valve. It is held in by two screws and has two small coolant lines attatched to it. I still need to get this confirmed but I'm pretty sure thats what it is. If you take the two screws out it will easily pull out of the intake. it is different than your normal pcv valve but it is definately an air driven valve and is connected to the top of the passenger side valve cover. The two small coolant lines are a total mystery to me!?
Polly
Dec 8, 2015 03:19 AM
cgh
Jun 3, 2006 10:25 AM
run79dar
Mar 14, 2006 05:01 PM
hrybls
Oct 8, 2005 01:41 PM
tlinley
Oct 7, 2004 07:46 PM
