Loss of power in rear doors - 2011 F150 Supercab XLT
Old Jul 22, 2024 | 08:55 AM
OkFord27's Avatar
Default Loss of power in rear doors - 2011 F150 Supercab XLT
I recently upgraded my speakers and immediately noticed that the back ones were underpowered. After about a week I noticed there was no sound coming through at all. While checking the doors, I discovered that the switches don’t work either, though I can still operate the windows using the front control panel. I've searched online but haven't found any information explaining this bilateral issue. I suspect it may be a fuse problem, but I haven't identified the specific fuse causing this. If anyone could refer me to a relevant thread or provide information on how to fix this, I'd greatly appreciate it!
Old Jul 22, 2024 | 04:55 PM
You said the switches don't work any longer while checking the rear doors. What switch, door lock + window combo switch or door ajar switch or both? Both rear doors?
Old Jul 22, 2024 | 05:11 PM
OkFord27's Avatar
Okay, I figured out the window issue. The window lock was gummed up and stuck halfway in the off position. Didn’t fix the issue with the speakers, but definitely is a little relieving. I checked it yesterday!
So knowing that it’s not a power issue, what might cause the rear speakers to go out? I checked their harnesses and the connection is solid all the way through the grommet.
Old Jul 22, 2024 | 10:19 PM
To my understanding thus far, you upgraded the speakers only, not the wires. How do you know your wires are capable to handle the upgraded speakers?
You checked the harness and connection at the grommet visually, but you didn't check for bad wiring.
What I would do, bench test the speakers or test by running your spare new speaker wires or electrical wires if you don't have any spare speaker wires directly from your stereo to the speaker and bypass all your existing wires, then you can tell if you need to replace or upgrade your speaker wires to the rear.
Old Jul 22, 2024 | 11:24 PM
OkFord27's Avatar
Dang, I was hoping you wouldn’t say that. I’ll get on that tomorrow morning and I’ll see what I can figure out. Thank you!
mudminnow
May 23, 2023 02:42 PM
Dcornish
Apr 1, 2023 04:59 AM
speekpe
Apr 10, 2019 06:53 PM
work.truck
Mar 12, 2015 11:28 PM
ldybwhntr
Jun 22, 2011 08:29 AM
