No Start
Old Nov 27, 2019 | 05:37 PM
F150-07-4.6's Avatar
Default No Start
I have the 4.6 intake and all back together, Now no start, I have reset the fuel cutoff just in case it was that. Went over all the hoses and everything is just fine. Also reset the computer by touching the neg. cable to the pos. terminal too. Any help would be great as you guys really know your stuff. Thanks in advance for all your help and Happy ThanksGiving too..... Mitch
Old Nov 28, 2019 | 07:58 AM
What does your check engine light do when you ate attempting to start it?
Old Nov 28, 2019 | 09:11 AM
It comes on for the check, Then goes off with all the other lights. I get NO codes neither. Where can I find the owners manual for this truck. I misplaced mine.. sheeshhhh. It actually almost started this morning but then just keeps turning and a peck here and there..
Old Nov 28, 2019 | 09:25 AM
OK, I just got the owners manual online and I'm going to go over all the fuses just to be sure..
Old Nov 28, 2019 | 09:57 AM
All the fuses are good,,,WTH. Imagine that...
Old Nov 28, 2019 | 10:58 AM
Got it .. I had the dam vacuum lines reversed... Thanks tho...
Old Nov 28, 2019 | 11:17 AM
Is there a bleeding screw somewhere for the coolant system. It doesn't say in the manual.. thank you again dude...
Old Nov 28, 2019 | 02:04 PM
There is no bleeding screw.
Not sure if you got it running , yes/no ?
Which vacuum lines did you have reversed, just curious?
Markito
Dec 26, 2016 03:09 AM
ahall1970
Dec 3, 2012 06:55 PM
farmer45
Jun 5, 2011 12:29 AM
fishfun83
Apr 9, 2009 04:13 AM
brytersward
Jan 9, 2006 08:30 PM
