One Brake Light signal Light not working
Old Jan 12, 2019 | 09:00 PM
fhenry's Avatar
Default One Brake Light signal Light not working
2004 Ford F150 2 wheel drive. One signal light and one brake light not working on the driver side. I have replaced all bulbs and the bulb socket on the rear driver side. Looking to replace the flasher relay next. I don't think it's the fuse, or it could be the Brake Light switch, but wouldn't that cause both lights not to work.
Old Jan 12, 2019 | 09:11 PM
Welcome to the site..
Do the emergency/hazard flashers function on that side?
Old Jan 26, 2019 | 09:08 AM
fhenry's Avatar
Hayapower,
No the hazard light did not work, but I figured it out. Initially I installed new bulbs on both sides. The blinker worked for a while but, would go out intermittingly. The old bulb socket was corroded and shorted the new bulb. I replaced the bulb socket on the left side and put the new bulb back in thinking it was good. I switched bulbs from the right side, and it worked. The other bulb socket is also corroded so I will need to do the same before it blows that bulb. Thank you for replying.
Old Jan 26, 2019 | 02:21 PM
Thanks for the update..
Zax
May 18, 2019 11:59 PM
moniker
Nov 23, 2017 12:01 PM
Fizgig
Dec 2, 2011 07:32 PM
tylyn
Dec 5, 2010 09:46 AM
BCBEEF
Jul 14, 2006 03:01 PM
