Running bad
Old May 9, 2024 | 05:31 PM
Stu70's Avatar
Default Running bad
I have an 05 F150 5.4 XLT. I had my transmission rebuilt and ever since I picked it up it hasn’t been running properly. When I am on a flat road and coasting at around 40 mph,, if I very lightly touch the gas, the truck pauses and has a subtle jerk to it. If I press the gas a bit stronger there is not a problem. It only occurs when I give the truck just a little bit of gas. I took the truck to Ford and paid them for a diagnosis. They recommended number two and number four fuel injectors replacement.
I went ahead and did all four on the Bank one or passenger side of the engine.
It did help it a bit, but still has that subtle pause.
Any suggestions on what else I should do?
Old May 10, 2024 | 05:54 AM
Suggest , let it happen one or two more times then have the computer checked for any codes.
Intermittent problems don't always lite the check engine lamp , but will many times show a code which we can use for guidance.
stclist111
Jan 17, 2011 09:50 AM
milesnva
Feb 13, 2010 09:42 AM
raj828
Nov 4, 2008 04:32 PM
96F350Panel
Nov 27, 2007 02:59 PM
kd7skx
Aug 14, 2007 06:32 PM
