still trying 92 F150
Old Mar 10, 2012 | 06:17 PM
grindman's Avatar
Default still trying 92 F150
I have a 92 F150 damn thing tries to run in start position but won't run in run pos. I am at witts end with my truck. If It won't run when I need it to
then I'll have to get rid of it though I'd rather not do that any help please
Floyd
Old Mar 11, 2012 | 03:10 AM
If you have a test lite available, just clip the alligator clip to a good ground , turn the key to the on position and check if you have a light at the coil ign terminal.
If not , the ign switch is suspect. It uses the same wire to feed the coil in either the start or ign on position.
Old Mar 11, 2012 | 11:29 AM
grindman's Avatar
I'm beginning to think that I might have a fuel delivery problem with it. I'm way too poor and way too dumb about e.f.i. when a artificial brain takes any
way of getting fuel into the cylinders from me I get to the point of no return
and all I want to do is take a baseball bat to it. But all my frustration aside, if I replace the fuel pressure regulator would it start the injectors working or would it still not start?
Old Mar 11, 2012 | 12:54 PM
It helps if you stick to one process at a time. Instead of jumping all around, were you able to try the test with the test lite?
Old Mar 11, 2012 | 12:59 PM
grindman's Avatar
not a test light with analog meter coil and wire still good
Old Mar 11, 2012 | 01:02 PM
grindman's Avatar
i'd still rather put a 460 in it with a c-6 behind it and get rid of e.f.i. all together
Old Mar 11, 2012 | 01:05 PM
grindman's Avatar
there's still plenty of them around here
Old Mar 11, 2012 | 01:11 PM
grindman's Avatar
I just wish that all companies tried a little K.I.S.S. while building these darn things at least the dependability would still be there
Old Mar 11, 2012 | 01:14 PM
grindman's Avatar
Sorry Hanky . I thank you ever so much for the help. If you ain't guessed by now I absolutely hate E.F.I. engines.
Old Mar 11, 2012 | 04:42 PM
A lot of folks have a tendency to dislike something we don't understand. So what's wrong with that ?
Depends what it is. When EFI first came out a lot of people threw up their hands and quit. Then the info began to come along and all of a sudden it wasn't so bad.
Could you tell us what you checked with the meter so we can understand what you did?
It's important to know exactly where you placed the probes and what results you received. No apologies necessary, lets just get the problem solved, usually by taking one step at a time.
