wire diagram for ign sw
Old Jul 31, 2025 | 11:14 AM
ken clark's Avatar
Default wire diagram for ign sw
i am doing a ign bypass on my 07 f150 xlt v6 using 2 switches and a push button sw. i need wiring blueprint of what wire to put where. my colors are blk/red blk/green green/blk blue/green yellow red/ blue with blue/green and green/blk being slightly bigger wire
any ideas?
Old Jul 31, 2025 | 01:54 PM
Until someone comes up with a diagram,
With 2 sw does this mean you want one sw to supply power to what is supposed to get power when key was turned on AND the other sw to activate the starter ?
If so, do you have either a volt meter, or test light ?
Old Jul 31, 2025 | 01:58 PM
Old Jul 31, 2025 | 06:07 PM
ken clark's Avatar
Correct and yes i have both. i wired it up other nite and it worked perfect. Started it like 4-5 times no glitches.taped and zip tied wires up cleaned tools up put away. and i must of done something not knowing what or how but next morning it was back to security lite slow blink like no key in it. i left pats in tact just use key for handshake and to turn steering wheel.
Old Aug 1, 2025 | 07:40 AM
Hi Ken,
You bypassed the mechanics of the security system, but are overlooking the electronics of that system.
The functionality of your vehicle's system is controlled by the PCM.
What happens if you leave the key in the on position when you use your by pass to start the engine ?
That might satisfy the security system which you have not replaced.
By the way, that system still requires a coded key to get that light out .
Just out of curiosity, you have 2 vehicles you are getting involved in, and keep in mind their systems are very different and what you do with one will not work with the other, OK.
Old Aug 1, 2025 | 10:34 AM
ken clark's Avatar
Hi Ken,
You bypassed the mechanics of the security system-, but are overlooking the electronics of that system.
when i said two switches i meant two toggle switches the ign sw not in truck at all my bad
Old Aug 1, 2025 | 12:46 PM
ken clark's Avatar
thanks for the diagram will try and wire my toggle and push button this afternoon. also i forgot to mention that i was using a relay in this bypass just as an extra safety. once again thank you
Old Aug 1, 2025 | 01:29 PM
You didn't say or do anything wrong, I just wondered if you were working on both at the same time, my bad !
BuskingEconoline
Jul 31, 2025 09:03 PM
Jose Zamora
Jul 31, 2017 01:41 PM
mrwarejr
Feb 8, 2014 12:23 PM
AngelaL221
Sep 26, 2009 10:51 PM
ugbandtulsa
Feb 25, 2009 11:56 PM
