2001 Econoline starter circuit relay wiring/ no crank no start
Old Oct 25, 2023 | 10:13 AM
BuskingEconoline's Avatar
Default 2001 Econoline starter circuit relay wiring/ no crank no start
I had taken pictures but I was redoing my wiring and I lost pictures before I could Houston as a reference. I believe that I haven't figured out but I'm just wanting to see if anybody has it different solution. When I read it the wiring I believe I forgot to wire the what I think is the signal wire to both the relay and the ignition control module. But originally was the red and light blue wire is no longer there so I don't have a reference at all as I replaced that too. But I feel like I'm missing something still, is the wiring diagram is also including that wire to the transmission rain sensor I thought but the more I look at this The more I get a little bit confused because I definitely did not disconnect any wires from the transmission range sensor but is that the same thing as the manual lever position sensor as this diagram calls it. Cable tracer that I'm using literally does not have a signal as I try to track it to anywhere at the fuse box. So should I be looking for where exactly the white and pink wire is attached and be attaching it to the other side of that? And because I have that cable tracker if I wanted to back probe it in a way what should I be attaching that to in order to trace it back to a wire leading to the starter motor relay and or transmission range sensor. Different ways to ask the same question I know but I'm just wanting to make sure it's clear what I'm trying to do simply that I forgot a freaking wire.
Old Oct 26, 2023 | 03:38 AM
We should be able to offer some assistance, but we need to know why you started this and what kind of wire are you using to replace what you removed.
Are you using only one color and gauge? If not , then what, important since all wire is not the same.
As you know by now, the smartest way is one wire at a time.
Old Jul 31, 2025 | 06:22 PM
ken clark's Avatar
Did'nt really replace any wire just added a fused 6awg from battery to switches then added 12 awg very short to reach the spacing of switches to my alum angle i mounted switches
Old Jul 31, 2025 | 06:26 PM
ken clark's Avatar
Thats pretty much how i did it but where i messed up is i did not document what i did
Old Jul 31, 2025 | 06:37 PM
ken clark's Avatar
i started this for i was stranded and confirmed switch was worn out and was shutting truck down like i turned key off. my friends neighbor [ farmer brown kind of man] i made it home was headed to a job next morning needless to say i did'nt make it. only has 298,008 miles just getting broke in i think
Old Jul 31, 2025 | 09:03 PM
ken clark's Avatar
mannext to where i broke down was so very helkful and he had everything i used he gave to me saying pay it farword which i thanked him and said yes sir
2013 galaxie gal
Jul 14, 2016 11:58 AM
mrwarejr
Feb 8, 2014 12:23 PM
Mainmcg
Aug 24, 2012 03:59 AM
turbo79
Apr 23, 2007 12:56 AM
Darr67
Jul 29, 2006 02:18 AM
