$400 truck need help.
Old Jul 3, 2022 | 09:54 PM
EDW99's Avatar
Default $400 truck need help.
Hello new here don稚 know if I知 even posting this in the right place. Anyway bought a 95 f250 with a 5.0 2wd the guy I got it from said he parked it 8yrs ago because it needed a transmission. I got it put all new brake lines on it not by choice but because once I fixed one another blew. Then a full tune up. They guy we got it from had another truck with the e40d in it and said if we pulled the motor we can have the transmission. So we did that now that the transmission is in with a new TC and fresh fluid it痴 doing the exact same thing it was doing. It was go in drive and reverse. When you drive it値l hold first abnormally long then hard shift to 2nd. It値l also down shift but jerk you. The gauge cluster has no odometer reading and no speedo. I checked all the fuses and they are good. I知 just wondering if it really is a coincidence or is something else wrong. At this point I知 completely ok with buying Tannerite and blowing the whole thing.
Old Jul 4, 2022 | 06:44 AM
Sounds like a speed sensor problem.
If the same problem with 2 transmissions, could be coincidence, but would look for possible wiring problem if speed sensor is OK.
Old Jul 11, 2022 | 01:41 PM
69xlch's Avatar
I'm no expert but I'd bet the instrument panel is the problem. The computer that runs the trans will pick vehicle speed readings from the cluster. Late /hard shift is classic sign of a trans not receiving VSS (or governor) input
Old Jul 11, 2022 | 06:33 PM
I agree it could be the cluster since he is getting no readings, but if the speed sensor info is not getting to the cluster,then what?
Scan tool may not show the info we want because 95 was a transition year and OBDII was not required yet.
Speed sensor signal should be verified and if present , then I would agree could be cluster
A lot cheaper changing a speed sensor than a cluster if we have no way to verify..
Old Jul 12, 2022 | 05:31 AM
bismic's Avatar
Probably already used tannerite, lol.
Hasn't logged on since the post!
Old Jul 12, 2022 | 07:48 AM
And all the while I thought it was fourth of July celebrations. lol.
Old Jul 12, 2022 | 08:02 AM
bismic's Avatar
lol !
acinatx
Dec 27, 2021 11:55 AM
Kennyd63
Mar 15, 2014 07:35 PM
Disruptive
Mar 13, 2013 06:12 PM
digitalincome
Feb 26, 2010 06:45 PM
QuickSilver
Jul 14, 2009 04:18 AM
