1981 Speedometer Cable Gear/Transfer Case Gear Not Meshing
Old Aug 14, 2017 | 12:40 PM
KRinAZ's Avatar
Default 1981 Speedometer Cable Gear/Transfer Case Gear Not Meshing
Hi All, I just bought an old 1981 F250 Custom 4x4 (details in my sig) with an inoperative speedometer.
I verified the speedometer itself is good, then verified the cable is good and the gear turns the cable nice and smooth.
When I have the cable inserted in the transfer case I can still spin the cable at the speedometer end - so it appears the gear at the end of the cable is not meshing with the gear in the transfer case on the output shaft.
I put my finger in the cable hole and feel a gear on the tx case output shaft.
Perplexed...
Could it be I need a bigger gear at the end of the cable? That will change speedo calibration though...but it's probably off anyway...
There have been some parts swaps from a PO - the original 351 was (sadly) swapped with a 460, I don't know if the trans or transfer case were also swapped. The original wheels/tires were 16.5x6/8.00-16.5D and it now has 16x6/LT235-75R16
Also the cable hold down bolt at the transfer case (BW 1345-12) is missing if anyone knows the details of that bolt.
Any thoughts on how to troubleshoot or what to look for to get the speedo cable to mesh with the tx case?
Fredo181
Feb 4, 2017 01:03 PM
Jmcwilliams1108
Aug 27, 2016 07:16 PM
jhamil25
Nov 2, 2012 05:13 AM
1967 f250
Aug 20, 2007 07:11 PM
Tempestv
Jun 9, 2005 02:00 AM
