2 questions about F450, DEF and headlamp assembly
Old Aug 4, 2017 | 06:19 PM
RichardAF450's Avatar
Default 2 questions about F450, DEF and headlamp assembly
Hello all:
I drive a F450 for a local company and had the misfortune of bumping into a large, stationary RED garbage dumpster. I busted the passenger headlamp assembly (and a dent in the fender).
Newbie here but two questions:
- can the braintrust here recommend a good vendor to find a replacement? I ordered one already, but apparently there are more than one type for the F450 super duty. Economical would be helpful. (2013 F450 super duty, XL, 6.7)
How long does the DEF typically last with medium duty hauling (loads, no trailers). Load values are up to 7000#, typically 1500-4000# 100-300 miles a day.
Thanks in advance.
Old Aug 6, 2017 | 09:05 AM
I realize this may not be the most economical choice, but if it is important to get the right part the first time , if you provide your Ford dealer parts dept with the VIN, you should get the right stuff and do the job once. DEF consumption is also influenced by engine running time. Best to check it with every fuel fill up.
starbob45
Sep 28, 2017 07:48 PM
marine0688
Jan 31, 2016 03:44 AM
kmacken2003
Apr 28, 2008 06:03 PM
450 tuff
Oct 25, 2007 10:18 PM
FordF450
Jul 26, 2007 11:49 AM
