2004 F350 keeps blowing fuse 17
Old Feb 20, 2022 | 09:56 AM
Johnfulks2's Avatar
Default 2004 F350 keeps blowing fuse 17
I have read and read and cannot find my issue. I have pulled the harness for the rear and completely checked for issues with none noted. If I disconnect the rear harness the fuse does not blow at all. If I plug in the harness and turn on the lights I have no rear lights but the fuse does not blow. If I turn on automatic lights it blows. I replaced the switch without automatic lights. It doesn't blow but I still have no tail lights or brake lights. I have disconnected the brake switch still have the same issue. I can not find and bare wires under the console either. Can anyone help?
There are no aftermarket additions either.
Old Feb 20, 2022 | 10:43 AM
Johnfulks2's Avatar
Default Fuse 17 issue
It said exterior lamps. I just pulled the fuse box and could not find any issues. I pulled the turn signal and could not find a wire short but now I just have hazards on one side. Both turn signals work.
Old Feb 20, 2022 | 11:03 AM
Johnfulks2's Avatar
Interior fuse panel.
Old Feb 20, 2022 | 11:05 AM
Johnfulks2's Avatar
Old Feb 20, 2022 | 11:06 AM
Johnfulks2's Avatar
Interior panel. I sent a photo but it must be reviewed.
Old Feb 20, 2022 | 12:03 PM
bismic's Avatar
Are these the applicable diagrams for your truck?
Old Feb 20, 2022 | 12:15 PM
Johnfulks2's Avatar
That is the same as mine.
Old Feb 20, 2022 | 02:18 PM
Johnfulks2's Avatar
What does that mean/ entail?
Old Feb 20, 2022 | 02:48 PM
Johnfulks2's Avatar
So should I take it to the dealer? They are outrageous here in KY.
Old Feb 20, 2022 | 03:18 PM
bismic's Avatar
Circuit 195 (B) from page 13-7 comes from fuse 17. It also seems to have a "tie" to the vehicle security module.
