7.5 engine will hardly turn over?
Old Mar 28, 2021 | 11:43 AM
balzac's Avatar
Default 7.5 engine will hardly turn over?
Bought a 86 f350 cutaway motorhome. Just beforeI I bought it another person tried to start it as it sat for 3 + years. Has 100,00 miles, he used ether while cranking but didn't fire. Then I decided to buy and replaced the starter and solenoid, but now barely turns over while boosting. Cannot guess what is wrong, did the starting fluid dry the cylinders?. Should I remove the plugs and add lite weight oil to each cylinder, then see if it will crank?
All ideas appreciated.
Old Mar 28, 2021 | 01:45 PM
It probably would be a good idea to remove a few plugs to see if they are getting fuel or if they are dry. Don't remember if they had a manual or automatic choke.
You do realize the fuel in the vehicle is stale and may not want to burn and start the engine.
The one reason I don't recommend starting fluid is because most people use WAY TOO MUCH ! I have seen where it blew holes in pistons or took the tops off.
It can also cause what may sound like a hydraulic lock where the pre ignition prevents the engine from rotating.
How good are the battery and the cables?
JHOCK
Mar 24, 2013 08:01 PM
benenuf
Mar 1, 2013 05:47 PM
GreatAwakening
Aug 18, 2012 10:47 AM
monergy
Aug 15, 2011 06:54 AM
gcarrboy
Apr 24, 2011 08:25 PM
