92 F250 460 Engine surges under load
Old May 28, 2018 | 03:14 PM
dsmith22707's Avatar
Default 92 F250 460 Engine surges under load
Engine can rev in park, neutral or while power braking with no problem however if driving up a small hill the engine loses all power. I have already replaced the fuel filter and pressure regulator. The truck did sit all winter. Wind shield has a leak on the driver side which as caused several gages to stop working (fuel, tach, battery). Engine does have a good coolant leak on the left side of engine (I can't find it yet). Any thoughts?
Old May 28, 2018 | 06:37 PM
What happens if you remove the vacuum hose from the EGR valve and plug it , then drive it?
Old May 28, 2018 | 07:26 PM
No change. Maybe loss of power is not the right phrase. The engine cuts out under load of driving up a slight incline. The engine never dies its just surges back to life. Almost like it is being starved for fuel but it doesn't do while in park.
Old Jul 18, 2021 | 10:16 PM
jmack108's Avatar
Default If your still here
Did you ever figure out what the problem was? I am having the same sort of issue. Thank you
Welderguy
May 19, 2020 06:18 AM
dankris007
Feb 9, 2016 10:09 AM
sectlandscaping
May 4, 2012 05:38 PM
rscottmoses
Jul 29, 2011 07:50 AM
302nut
Jul 8, 2011 06:09 PM
