95 F350 5.8 running extremely rich
Old Dec 30, 2020 | 08:01 AM
ljinnc12's Avatar
Default 95 F350 5.8 running extremely rich
I have a 95 F350 with 5.8 that sometimes runs great then other times it starts and runs very rich to the point that it's not driveable, spits, sputters, black smoke pouring out the pipes. The fuel pressure regulator was changed, the map sensor was changed. What else should I try? Thanks
Old Dec 30, 2020 | 10:39 AM
One thing you might consider,
Get hold of a fuel pressure gauge, connect it to the schrader valve on the fuel rail and watch what is happening with the fuel pressure. That way you will be sure the fuel pump is not pushing excessive pressure and also that the pressure regulator is operating correctly. Fuel pressure should be 35-45 psi.
D1995
Nov 9, 2019 08:30 PM
SoundFXRI
Oct 25, 2010 06:31 AM
HorchataKing
Jun 20, 2009 01:56 PM
HorchataKing
Apr 18, 2009 01:55 AM
g2redgsr
Nov 18, 2007 04:51 PM
