carb leak
Old Dec 14, 2007 | 10:33 AM
kentucky_country_boy's Avatar
Default carb leak
i have a 78 f250 4x4 and the bottom of the carb leaks not bad but it still leaks. i wanna know what is the most common leak and how i could fix it. put a new gasket in it or new bolts
Old Dec 14, 2007 | 11:49 AM
Default RE: carb leak
OEM carb?
It has an vacuum/intake leak at the carb base?... Correct?... Or a fuel leak down low? Power valve at the bottom of the float bowl can weep/leak (usaully will make for a flood/hard start) as well as the accelerator pump with age.. Carb S/B on 5/16 studs, and shouldn't need to be replaced.. If it's the base gasket, make sure the replacement has the plastic collars at the mounting studs to protect from over torque/bending.. As well as check for carb flange flatness during a gasket replacement.. EGR plate gasket would be replaced as well....
miamipammy
May 27, 2007 04:40 AM
truefordman73
Oct 26, 2005 01:22 PM
ziggdaville
Sep 29, 2005 01:59 AM
sideways4m
Sep 9, 2005 07:05 PM
hicracer
Jan 27, 2005 03:31 PM
