coolant leak 7.3
Old Aug 25, 2017 | 04:03 PM
eric hoffmeyer's Avatar
Default coolant leak 7.3
1999 F350 7.3 diesel
Noticed a steady drip coming from the area right behind the front crankshaft pulley.
I'd appreciate advice on locating the leak and the steps needed to repair.
Thank you.
Eric
Old Aug 25, 2017 | 04:16 PM
Hi Eric,
What may help would be to get hold of a cooling system pressure tester and pump it up to the pressure shown on the radiator cap (some are 7lbs , some are 15 lbs). It could be something simple like a loose hose clamp or hopefully not a water pump seal. Usually that will allow you to see the source of the leak. If it is the pump , let us know, maybe we can save you some grief.
Old Aug 25, 2017 | 09:45 PM
T stat housing was a good weep point, pump, or oil cooler and of course hoses.. Pressure test like mentioned helps spot them bleeders..
Old Aug 27, 2017 | 09:56 AM
Thanks guys!
I discovered it was the water pump. Swapped it out yesterday and all is good. For a moment i thought i was going to need to pull the front engine cover. Glad that was not necessary!
Eric
Old Aug 27, 2017 | 10:00 AM
Thanks for the update !
IAHAWKS
Mar 1, 2008 05:00 PM
alldonein
Dec 13, 2007 06:48 AM
jr1017
Jul 25, 2007 09:54 AM
kbsc
May 7, 2006 04:53 AM
kpmc1206
May 8, 2005 05:10 AM
