Dash Removal in 1992 F350
Old Oct 23, 2011 | 08:01 AM
barkfarm's Avatar
Default Dash Removal in 1992 F350
Someone have some good tips on the easy way to remove dash. Have to work on the light switch wires have a short in them
Old Oct 23, 2011 | 01:46 PM
I can tell you it's very easy to pull the plastic away and remove the switch.
In order to remove the **** and shaft that goes into the light switch so you can get the plastic out of the way , there is a small button located on the bottom of the light switch itself that needs to be depressed and while depressing that button pull the **** and shaft out of the switch. The rest you will be able to see with no problem. You may want to remove the negative battery cable because when you pull the **** out it will leave the headlights on until you reinsert the shaft.
bodydropped72
May 1, 2008 11:43 AM
adelssalisbury
May 4, 2007 03:28 PM
adelssalisbury
Apr 30, 2007 07:02 AM
dj_mindframe_99
Nov 11, 2006 07:28 PM
retiredlarry
Jun 7, 2005 05:48 PM
