F250 "bad" BCM
Old Feb 24, 2024 | 10:01 AM
Copestoo's Avatar
Default F250 "bad" BCM
Hello, I have a 2011 F250 6.2 with 175000 miles on it. It has a large power drain (it will kil the battery over night) and I have been told it has a bad BCM otherwise known as a Door Lock And Alarm Module. A new one is absurdly expensive and I am loathed to spend that much. This leads me to my question. Is the "bad" module physically malfunctioning or is it software? How would I tell? I have ordered a USB OBD connector and will purchase a FORScan license. If It is software can I flash the as built to it and correct the issue? Question Number 2, IF I buy a used BCM that has a different part number (for whatever reason the part number on mine is scarce) can I flash the as built for my truck to the "new" bcm and it operate correctly? I have not done this type of work before so I would appreciate any help any of you would be willing to provide.
lmarcum91
May 25, 2023 03:59 AM
sla1@pct.edu
Mar 19, 2022 08:23 AM
DJenkinsABQ
Aug 17, 2015 09:04 AM
kingofbling
Mar 4, 2008 02:43 PM
bmiller
May 6, 2005 09:00 PM
