Head light replacement
Old Apr 6, 2018 | 08:34 AM
eric hoffmeyer's Avatar
Default Head light replacement
1999 F-350 XLT model
The lenses on my head lights are yellowed and can't be cleaned from the outside.
I'd like to replace the head lights with something better but nothing crazy wild.
Any suggestions or prior experience with a particular item?
Thank you.
Eric
Old Apr 6, 2018 | 09:37 AM
Hi Eric,
There are several kits on the market that will help clear up the fogged lenses. I did use one made by "Mothers" . It came with different grades of pastes that when applied with the foam applicator and a battery operated drill did a pretty decent job. I'm sure various auto supply stores have some kits at reasonable prices that will work. The cost to replace the headlight lens unit can also be considered, but will cost considerably more. It does make a big difference when the lens is clear.
Old Apr 6, 2018 | 01:40 PM
Hanky, Thank you. It seems however that the lenses are clouded on the inside. I did try some small areas to attempt to clear up the outside as a test. But unfortunately that didn't make a difference.
Thanks!
Eric :-)
Old Apr 12, 2018 | 07:33 PM
JakeFast324's Avatar
A lens cleaning kit costs less than $20. Many actually work really good. I would try that before spending hundreds on new lights. But, if you're already decided, I would go with an LED conversion if your spending the money anyways, you might as well get the best tech available.
ShawnK2017
Nov 16, 2017 08:32 AM
Sooperbohl
May 16, 2013 12:30 AM
bill9iron
May 6, 2009 06:22 PM
Mad Cow
Jul 22, 2008 10:41 AM
kaboom10
Feb 1, 2008 09:23 PM
