PCM issue 2001 F250 7.3 liter
Old Dec 15, 2020 | 07:25 PM
progressive155's Avatar
Default PCM issue 2001 F250 7.3 liter
Need Help
I have a 2001 F250 7.3 liter Super Duty with 293K on it. It started throwing transmission codes and shifting wierd. I brought it to a transmission repair shop and they said I had an electrical issue and to take it to a repair shop. The repair shop replaced the harness for the transmission and that did not help anything. Next was to replace the PCM. The truck was manufactured for California, so it has special emmisions and only so many of them were made. The mechanic couldn't locate a used one, so he suggested sending it to a place where they remanuafacture them. After wait for 4-5 weeks, I recieved a call saying the remanufactured PCM did not work. The mechanic said it is a special PCM only manufactured for one year specifically for sale in California. Code is DPC-452 NMC3. I don't know where to go from here. Thanks,
John
Old Dec 16, 2020 | 08:05 AM
There are folks on this forum that reside in California. They should be able to recommend a place there that would be able to come up with the Cal. required part.
I believe our Moderator , Hayapower, might be able to help you with this.
Old Dec 16, 2020 | 12:56 PM
What were the codes displayed?
OD light flashing?
Shifting weird, how so?
Trans was a reman at some point/mileage ?
Being codes are being stored, engine runs fine (?) Id be suspect of another issue other than PCM, more so, if that trans was OE and high mileage as you stated...
Josh Peters
Aug 16, 2020 06:43 AM
Tim Redding
Jun 17, 2020 07:13 AM
Scott Desjardins
Aug 17, 2017 11:35 PM
Aggie84
Jun 13, 2012 07:25 AM
banjomax
Nov 30, 2010 01:05 AM
