tow haul and 4WD at same time?
Old Jun 18, 2019 | 01:33 PM
plumcreekbob's Avatar
Default tow haul and 4WD at same time?
I have a 2010 F350 gas. Should I be able to use tow haul and 4WD at the same time? If I use 4wd high or low, the tow/haul light goes out. I asked the ford dealer and they were unsure if the two would work together since both function to adjust the transmission. Any thoughts? no codes
Old Jun 18, 2019 | 02:04 PM
Since 4WD, on your vehicle, is meant to be used on slippery roads and not recommended on dry roads You probably can use 4WD to park, or tow maybe from a ramp or steep take off spot, but I don't believe it is recommended for regular driving on dry pavement.
Did you check what your owner's manual instructions might say?
Old Jun 18, 2019 | 02:08 PM
More info... I had a trailer of hay behind truck ~11,000 lbs. I had to descend a steep grade in hay field to get back to the road. I do not use 4wd while towing on the road.
hilliad
Jul 4, 2010 02:26 PM
kman711
Oct 13, 2007 09:54 AM
yummyshortcake
Jun 8, 2007 11:50 AM
jcarini
Apr 1, 2007 07:09 PM
Bigg_billy
Mar 9, 2006 01:27 PM
