truck won't run
Old Feb 2, 2021 | 11:52 AM
AZoldfart's Avatar
Default truck won't run
1988 F350 Lariat Super Duty
Have changed both the fuel pumps (in tank and on frame) Truck will idle but when i try to drive it.. it keeps dying .... restarts then dies again
Any clues to where to go next will be great
Thanks
Old Feb 10, 2021 | 07:43 PM
outriggen's Avatar
I had a similar issue and mine ended up being the pigtail going into the lift pump on the frame. It had corroded out most of the way so when you needed minimal amperage (idle) it sounded like it was fine but under load it would not carry enough power trough it. You can test with a multimeter set in 10 amp and putting the leads inline on the positive wire to it.
Old Feb 11, 2021 | 06:21 AM
I have seen many times where a defective coil will do this.
Danny2020
Dec 25, 2020 11:59 PM
greyheadedguy
Sep 30, 2012 11:14 PM
paulolin
Oct 27, 2011 11:21 AM
rick32
Jun 10, 2011 09:14 AM
Saskatchewan F-350 SuperDuty Lariat
Dec 20, 2010 08:54 PM
