Y2K PSTD w/o Turn signals or Brake lights
Old Nov 17, 2007 | 12:32 PM
Arlo Baulzitch's Avatar
Default Y2K PSTD w/o Turn signals or Brake lights
Hi all-
I've looked through the search function to try to trouble shoot this but with out any luck. I have a Y2K PSTD 4X4, CC, DRW with 94k miles. I lost my left turn signal/brake light first then a few days later the right side. I still have the third brake light. My 7 pin trailer outlet works and I have been driving around w/ my emergency trailer lights zip tied to my bed cap for too long. I've checked the fuses. The owners manual walked away one night in New Orleans along with my trailer brake and GPS units so I don't know for sure which fuse/relay it might be. I have a Haynes but it's not helping too much. Do you guys think(Mr. Haya!) that it is the Muti-function switch or flasher relay? I saw a previous post about a bad ground on the rear drivers side. Haven't been able to find where that is located. Inside or outside of the C-channel? Do I need to drop the spare? (That appears to be frozen and won't drop down).
Thanks folks, I just found the forum and you guys are the best source out there!
Old Nov 17, 2007 | 11:41 PM
Default RE: Y2K PSTD w/o Turn signals or Brake lights
You can download a owners manual here... https://www.fleet.ford.com/maintenan...ls/default.aspYou have checked the bulbs? Check the fuses in the Central Junction Box #1/20amp, and #24/10amp for power feed to/through the flasher relay and into the multifunction switch.. Since the high mount stop lamp is working eliminates the brake peddle position switch, and power distribution to the switch for stop lamp function.. Does the hazard flashers work? And do the panel/turn indicators illuminate ect? A bad harness ground at the chassisL/R generally won't cause a Right, and then Left lamp failure, nor would a current failure from a blown fuse ect..Possibly the M/F switch since they do fail, but make sure there's applied power where there needs to be before moving on......
Old Nov 18, 2007 | 10:39 AM
Thanks for your reply, I did check all the bulbs, they are good. No hazards at rear except for the emergency trailer lights out of the 7-pin.
The panel/turn signals indicators work(on the dash correct?).I've found that the turn signal stalk doesn't always "lock" in position when I go to signal. Do you feel that could be part o the problem? This would be what I would need to replace correct? http://info.rockauto.com/Motorcraft/...tml?SW5579.jpg
Thanks again, goin' out to triple check those fuses again.
Old Nov 18, 2007 | 12:26 PM
Yes, that is the Multi Function switch..
If thelock in the MF switch isn't staying locked with the steering wheel in a straight position I'd replace the switch for just that reason.. I'd suspect the fuses to be good since the flashers work (at/from the trailer adapter.. The functions for stop/turn split off at the MF switch for the vehicle lighting, and then the trailer lighting.. The ground for vehicle and trailerlighting (trailer connector/adapter) is shared at the L/R chassis so it should be good since your trailer adapter is working..
stevprin
Jul 15, 2019 08:33 AM
TerraHauler
Apr 30, 2015 05:18 PM
CADOP
Jan 1, 2011 05:58 PM
stac
Nov 23, 2010 06:09 PM
93f250xlt4x4
Jul 3, 2008 10:02 AM
