p2544 Transmission Code - Hard Shifts/Stalls Out
Old Aug 15, 2015 | 09:12 AM
Airman89's Avatar
Default p2544 Transmission Code - Hard Shifts/Stalls Out
My 2005 Ford Five Hundred was in an accident not long ago and a few codes were present afterwards besides the Air Bag. I have fixed all engine related codes besides a P2544 Transmission code.
The accident slightly caused the bumper support to push into the radiator bending it a little. When I shift to reverse from park, it is a very hard shift jerking the car.
What would cause the transmission to throw a P2544 code? Someone said that the transmission cooler could throw this code but I can't see how as long as the lines weren't broken or cracked and fluid still flows through but correct me if I am wrong.
Thank you.
Old Aug 16, 2015 | 08:28 AM
There may be more than one problem present.
Has anyone checked the motor mounts?
It amazes me that a new vehicle can perform flawlessly and then later on it requires a reprogramming. Are these built in failures ? If it is blamed on electronics it might be time to have the electronics parts made here in North America. Reprogramming is what might be required to correct the P2544 code.
Old Aug 16, 2015 | 08:45 AM
Airman89's Avatar
I had been working on my car and had a the intake apart but all sensors still plugged in when I would start my car, this was when the code was first thrown, I reinstalled the air filter box and hooked everything back up, now the wrench light is gone and it shifts great but it still says service the transmission? Will I need it reset?
I can't believe doing something so minor can throw a "more serious code". I miss the way cars used to be.
firef1523
Jul 28, 2010 07:37 PM
MagneMan
Feb 17, 2009 06:21 AM
zancom
Feb 25, 2008 09:15 PM
98mkiv
Mar 9, 2007 04:07 PM
E
Dec 7, 2006 09:30 AM
