Rhythmic Rubbing/Grinding Noise
Old Jan 1, 2021 | 01:25 PM
Zeke's Buddy's Avatar
Default Rhythmic Rubbing/Grinding Noise
Just having a heck of a time trying to fix my 06 Ford Five Hundred. It has110000 miles. I recently changed all the brake pads and front struts myself. I had a little trouble with the strut replacement procedure and it turned out the passenger side drive axle was totally shot. I found a replacement at a local salvage yard and everything went back together fine. It drove fine for a while, but now I am getting a sound from what I believe is unrelated to the tranny. Around forty mph it is really pronounced and never changes the same rhythm. Sound becomes faster with speed. I have needed new tires for a while, but money is tight. Anyone have the same issue? I also replaced the water pump with an aftermarket water pump. It totally smoothed out the engine, but have heard there are issues with anything but motorcraft oem pumps. I was actually amazed at how bad the old pump was. You can barely spin it. I wish I could take it somewhere and get it fixed so I can stop worrying about it, but I don't have the money right now. It just seems like something new breaks every time I fix something else.
Old Jan 2, 2021 | 03:30 PM
Welcome to the club.
Can you determine if the noise is coming from a particular area? Front, rear, left /right side, under the vehicle?
If it is tires and you want to do this switch tire positions and see if the noise moves to a different area.
If the problem wasn't present until you did the repairs, recheck your work and maybe the used part you installed was on it's way out.
Old Jan 4, 2021 | 03:59 AM
Daniel McMillian's Avatar
Default Run
I have replaced many parts on my 06 Five hundred Limited and let me tell you something. It just keeps going. Now I have to admit I have used primarily Rockauto economy parts except for spark plugs and wires. And I now have Mitchell1 so that helps but it just seems like the car is a ticking time bomb with the ridiculously priced transmission issue lingering. It’s a nice car in my opinion. Love the limited and it’s size and trunk space but honestly if you don’t have money to constantly put in it your in for a long road. With that being said I know your not gonna listen cause your invested like I got myself. So I would start with the tire rotation like buddy said already and then go from there. Keep us updated. Blessings to you and yours!
soopacee
Nov 8, 2016 12:34 PM
cover
Jan 29, 2013 06:33 PM
rounk
Oct 22, 2008 07:52 PM
561king
Jun 10, 2008 06:09 PM
91_ford_taurus
Jun 25, 2006 12:39 PM
