Small dash panel removal
Old Apr 4, 2024 | 04:12 PM
saemetric's Avatar
Default Small dash panel removal
I want to remove that horrible buzzer/alarm behind that small louvered panel to the right of the steering wheel on the dash. How to you remove the cover?
Old Apr 4, 2024 | 07:34 PM
A lot of dash panels are held in place with push in plastic retainers, some of which can break on removal if not careful
If you carefully pull the edges of the panel, you will feel them pop off. If you don't have experience with this type work, suggest you have a good shop handle it.
Old Apr 4, 2024 | 10:56 PM
Do you think your SRS system is working fine? When the airbag light lights up with your key in ON or RUN position (no others), that's a good sign that your SRS system is fine.
Why do you want to remove the warning chime. Which exact device is bothering you? headlight / ignition key / door / seatbelt / airbag / others
Old Apr 6, 2024 | 01:46 PM
Ahhh,
Heiko , brought up a good point !
The warning buzzer is going off to tell you something is wrong. You do realize removing the buzzer doesn't fix the problem.!
Suggest you find either through your owner's manual or some one familiar with the system what malfunction sets off the buzzer and once you know , then you can decide if it is wise to do so. What do you think ?
Old Apr 6, 2024 | 03:24 PM
You are right it’s better to disable per device instead of the chime globally. Seatbelts for instance you can use beltminder, the others maybe you can code them out or disconnect the ground circuit. Your srs system uses a separate chime and not sure if you can disable that at all. You need to find out which device is malfunctioning or just annoying then i can look up the service manual and get you the diagrams and instructions. I do have alldata for your car.
Old Apr 11, 2024 | 05:16 PM
saemetric's Avatar
The buzzer is working as it should….it’s just very annoying especially when I open the door with key in ignition. If I could remove the panel cover at least I could muffle it with a piece of foam.
Boomerang53
May 7, 2014 10:11 AM
dee004
Jun 23, 2008 07:36 PM
Easy
Dec 12, 2007 03:02 PM
capleton456
Jan 7, 2007 02:24 PM
retiredlarry
Jun 7, 2005 05:48 PM
