Brake problems
Old Dec 11, 2019 | 12:54 PM
Craftsman 62's Avatar
Default Brake problems
How do i adjust the emergency brake cable there's adjuster behind my back wheel which way do i go to tighten the cable.
Old Dec 11, 2019 | 07:53 PM
Don't know what your vehicle has, drum or disc brakes in the rear.
Drum brakes usually have self adjusters that adjust when brakes are applied backing up. If they are frozen or worn the cam arm will just slide over the star wheel instead of rotating it to do the adjustment. Parking brake cables can be adjusted at the parking brake pedal with several applications. Some ,not many, still may have an adjusting yoke where the cables from both rears join the single cable to the parking brake.assy. If that is what your vehicle has ,you just hold the threaded part with a pair of vise grips and turn the nuts clockwise. You should depress the parking brake 2 or 3 clicks and proceed to take up on the adjustment until you feel the wheels stat to drag . Stop there. Now when you release the parking brake , the rear wheels should be free to turn if in neutral with stick shift or auto trans.
Old Dec 11, 2019 | 08:37 PM
I have what u said cable coming frm each back wheel running n to one cable going to the pull up lever n the console between the buckets seats I will adjust the cable thx for ur input.
eric hoffmeyer
Nov 12, 2016 03:30 PM
wheelerbuffy
Mar 16, 2014 08:21 AM
mad.72
Mar 27, 2007 04:40 PM
ranchhorse
Nov 29, 2006 11:38 AM
roadrunner
Dec 10, 2005 07:21 PM
