M.A.F makeing idle bad then dieing
Old Apr 30, 2011 | 07:49 AM
ashvenger's Avatar
Default M.A.F makeing idle bad then dieing
cel was on had checked said M.A.F was bad (was unhooked ) an worse plugged in so i bought a new one $230 later new one installed disconnected negative reset cel ran bad then slowly got better ran fine at idle for about 5 min's before returning to bad idle then died stayed running about 45 to a min 30 before dieing
plugged in cel is off so i dont know where to check for problem
any one have a thought?
Old Apr 30, 2011 | 08:46 AM
When you disconnect the ECM , it needs time and driving to relearn. Be patient and drive it around for a while and give it time to relearn. If the MAF sensor was the problem and you corrected it , it should get better each time you take it out and drive it.
Old May 1, 2011 | 08:07 AM
ashvenger's Avatar
iv put close to 40 miles on it in town and a 4 mile stretch at 55
think it would take longer ,it sits at idle the worse it gets till i hear a clanking sound so i shut it down restart and rev it up ( not sure on the rpm's)
and it idles OK for a while then starts to clank driving is OK until i put the clutch in like say im coasting or put it in neutral up to a light its clanks and wants to shut down
sloancold
Dec 15, 2013 07:27 AM
ezauto
Jun 30, 2013 09:21 AM
rlpatte
Mar 31, 2012 08:45 PM
vault22
Sep 28, 2011 03:26 PM
amerstone
Feb 20, 2007 01:27 AM
