1993Lincoln Cartier Running Lean
Old Jul 13, 2021 | 05:50 AM
smi889's Avatar
Default 1993Lincoln Cartier Running Lean
The vehicle above has the 4.6L fuel injected engine and digital dash. The CEL comes on at about 3 miles driven which looks like at normal operating temperature. I get codes 172 & 176, too lean right and left sensor. So far I have replaced the fuel filter, fuel pressure regulator, IAT sensor, oxygen sensors, air filter and new plugs. Cleaned the MAF sensor, checked the plenum, fuel pressure is 32/40 and doesn't drop rapidly when the engine is shut off. I've also performed a smoke generator test with no detected leaks. The car starts fine and runs/accelerates good.I guess the question is, "What could be causing a lean condition when engine gets to normal operating temperature?" Don't have much hair to pull out at 78. Reset codes and is consistent pulling the same codes.
Meguinness
Mar 25, 2018 03:32 PM
Leefoo
Feb 18, 2016 10:43 AM
RodeoClown
Sep 5, 2012 09:10 AM
agoodname
Apr 23, 2011 05:34 AM
argneco
Mar 25, 2009 06:04 PM
