2012 Escape Diagnosing AC
Old Jun 3, 2024 | 10:46 AM
  #11
gilesitis's Avatar
Are you sure you had the fitting from the can to the low side ALL the way down so it depresses the valve core on the low side connection?
best I can tell the connector is on the port. I tried it again and once I released the connector, a high amount of pressure released. Almost like the port wouldn’t take the charge and just built up between the connect hose and low side port.
another interesting thing, is if I turn the ac on in the cabin, the engine will bog down for a second as if the compressor is turning on but it’s still not engaging.
Old Jun 3, 2024 | 01:28 PM
  #12
gilesitis's Avatar
One final thing to mention is I ran some diagnostics with FORScan and it’s showing a/c pressure of almost 400. Guessing if that’s correct I’m overcharged? Either way, I’m basically to the point where it’s over my head and will let a pro look at it.
Old Jun 4, 2024 | 07:17 AM
  #13
Pressure on the high side can reach that number, but it is still kinda high.
Without a set of manifold gauges to see what you are working with, you made a good decision to have a shop with the right equip and background handle the job.
Old Jun 4, 2024 | 08:10 AM
  #14
gilesitis's Avatar
I can be hard headed on these things and don’t know when to give up. However, I am learning HVAC stuff is not for average DIYer. Thank you so much for responding here and I appreciate the advice!
GNX500
Aug 2, 2023 08:17 PM
Jonmac
Oct 3, 2022 07:17 AM
Mattj62387
Sep 18, 2018 10:02 PM
Big-G
Jan 11, 2016 11:30 AM
66Landau
Feb 17, 2015 07:29 PM
