2012 f350 6.7
Old Jan 27, 2023 | 08:45 AM
Saltwater's Avatar
Exclamation 2012 f350 6.7
New here, Truck will not start unless I press the brake pedal down, wrench light on, ABS light on engine light on, No P.R.N.D1.2.3 light showing on dash. when driving truck runs like it's in 5th gear or limp mode, backup camera does not come when in reverse. Thanks for your time.
Old Jan 28, 2023 | 02:41 PM
We start with the simple things first. Check all the fuses, engine compartment and inside vehicle.
Old Jan 28, 2023 | 05:34 PM
Saltwater's Avatar
Thank for the response Hanky. I checked the fuse box in the engine compartment I don't believe I have a fuse compartment in the interior.
Old Jan 29, 2023 | 06:18 AM
Check your owner's manual, there is loads of info in there.
Old Jan 30, 2023 | 04:27 PM
Saltwater's Avatar
All fuses are good after checking truck started without having to press brake run fine all day on the way home while stoped I felt the transmission shift it went back into limp mode.
Old Jan 30, 2023 | 04:53 PM
There should be a code in the vehicle computer that could lead to the problem area.
After shutdown the code could be getting erased and the problem goes away , but when the problem is picked up again , the system to protect components goes into limp mode.
There is a function called "Freeze Frame" where the vehicle retains the data stream info and the tech can see where readings become irrational. That is the best way to pin down the source of the problem.
Old Jan 30, 2023 | 05:17 PM
Saltwater's Avatar
Code said TCM not responding to transmission.
Old Jan 31, 2023 | 07:24 AM
Best if you have a qualified shop verify the cause and replace the trans control module , IF NECESSARY.
Old Feb 1, 2023 | 05:40 AM
Saltwater's Avatar
Lol. I took it to three shops all of them said they're not sure what the issue is they don't want me to throw money at it, the earliest I can get it to a Ford dealer is February 27th it's hard to find a good mechanic these days hell for that matter customer service in general I appreciate your help...
Matty127
May 23, 2021 08:31 AM
Reedr
Sep 29, 2019 01:51 PM
ellen
Mar 26, 2011 04:12 PM
Farmdog
Feb 23, 2011 03:17 PM
dabutz
Sep 19, 2008 05:07 PM
