2012ecoboost
Old Feb 1, 2023 | 07:10 PM
smills's Avatar
Exclamation 2012ecoboost
Having troubles with electrical issues. I have a 2012 ecoboost and it will die at idle or while driving. I have changed the pcm and under fords recombination they moved the # 27 fuse I think that is the correct number and the dealership also changed a ground wire to the engine block. The truck stopped on the way leaving the dealership. I had a different shop try to find the problem. Has anyone has the same problem?
thanks for your help
Old Feb 2, 2023 | 05:56 PM
When you say die,,,,,,,,,,,,,,,does it die slowly or instantly just like if you shut of the engine.
johnmaran
8
Jun 23, 2022 07:18 PM
kathekas
Aug 21, 2021 01:20 PM
Toesasyuh
Mar 3, 2020 09:42 AM
nicksryan@yahoo.com
Apr 3, 2013 09:47 PM
excursionbeast
May 7, 2008 05:25 PM
