88 f250 codes 52-81-82-87-84 please help
Old Mar 29, 2018 | 11:59 AM
FreshLee14's Avatar
Default 88 f250 4.9l in-line6 no start!!!
I’m losing my mind with this truck, since it’s OBD1, I used jumper wire at EEC test port, I located both plugs but there is no relay to be found, must these plugs be relayed??? Also are check engine flash codes in 2 or 3 digit intervals??? Any help would be much appreciated
New parts- TPS, IAC, Solenoid, ICM, Starter, Terminals, Battery, Transmission, Negative Ground wire, ignition coil connector/pig.
The truck cranks but no start
PLEASE HELP!!!
LakelandF150
Mar 25, 2012 08:57 PM
llazarus10
Mar 7, 2011 05:33 PM
sweatyfatfreaks
Nov 10, 2007 11:30 AM
davequest
Sep 12, 2006 04:16 AM
