93 escort battery drain
Old Feb 28, 2013 | 05:11 PM
  #11
I believe the cable from the positive post on the battery goes to one of the terminals on the starter relay.
This is what I want you to try OK?
Take the negative cable off the battery terminal.
Remove the cable from the battery that goes to the starter relay and cover the end so it cannot contact any metal.
Now reconnect the negative terminal to the negative post on the battery.
Connect your voltmeter to the battery terminals and see what the voltmeter does.
Give it a few minutes, if the voltage does not drop there is a possible problem at the relay or something the wires there feed. Disconnect the negative cable again and reattach the cable to the relay and now remove the heavy wire from the alternator and do the same test and see what the voltmeter does. Be waiting for your reply.
What we're trying to do is isolate the drain. It has to be a big one to pull the battery down that fast ,,,,UNLESS,,, the battery is the problem.
The metal substituting for the hi current fuse tells us there is a reason that was done.
Old Feb 28, 2013 | 08:01 PM
  #12
dragonhunters3's Avatar
i figured out the problem the 4 pin connector on the alternator was full of gunk and not letting the current run threw to charge the battery
Old Feb 28, 2013 | 08:40 PM
  #13
Be careful there.
First,the "gunk" may be dielectric grease to prevent corrosion at those terminals.
Second, the output from the alternator goes through the heavier wire connected to a separate post on the alt.
If what you found solves the problem, great!
Old May 3, 2023 | 03:58 PM
  #14
Aungeliquema's Avatar
Dang the guy didn’t even come back and thank u for ur help and whether he got the problem solved! I’m guessing the problem was fixed. I just read this whole thread because my battery has a slow drain when it’s turned off I’m gonna make a new thread though about my issue thanks for taking the time to help that guy back in 2013
Old May 3, 2023 | 06:25 PM
  #15
All we can do is try.
Unfortunately, a lot folks forget to get back to us and let us know if their problem was solved.
Thank you for your courtesy and understanding.
Captain B
11
Apr 26, 2023 01:07 PM
dray5mil
Feb 18, 2010 05:37 PM
rdoble
Sep 6, 2009 07:39 AM
northerner
Mar 26, 2008 04:08 PM
ATASTEVENS
Jun 25, 2007 05:07 PM
