AOD in a 64 falcon
Old Feb 18, 2023 | 01:52 PM
parrothead4evr's Avatar
Default AOD in a 64 falcon
I'm looking to replace my C4 with a AOD from a previous mustang I owned. What kind of installation issues will I be looking at? Not gonna assume this is gonna be just a straight swap.....that'd be too easy, right?
Any help will be much appreciated.
Old Feb 19, 2023 | 04:43 AM
raski's Avatar
You didn't mention the engine you have in your Falcon. The issues I see are the bell housing likely won't match, the drive shaft length would be different, a C4 is vacuum controlled with a modulator, the AOD has a TV linkage meaning also a carb change, gear shift linkage is different, the mount is different, new cooler lines needed and I am sure I missed some things.Depending on your rear end ratio, having overdrive could make your Falcon a bogging dog.
Both are good solid transmissions. To me, I don't see any gain by changing transmissions and the change if possible will hurt the value and performance of your Falcon.
Old Feb 19, 2023 | 09:35 AM
I'm running a mildly built 302, and will be changing the rear gear to a 3.50 soon. It has a ford 9" rear.
Old Feb 21, 2023 | 03:06 AM
raski's Avatar
I would not attempt to make the change. There's no gain.
Old Feb 21, 2023 | 11:34 AM
Having once owned a 64 Falcon , was one of the best vehicles ever owned.
It never failed to start and had beautiful steering without power assist.
It did have one drawback, and that was the in line six had problems with compression blowing out the old road draft tube.
Back then I added a can of "Motor honey" and all that did was to hang curtains inside the engine that I saw after dropping the oil pan. Never use that so called sure cure !!
It was an overall good vehicle just as it was. Well built and reliable.
Old Feb 21, 2023 | 12:29 PM
Kind off topic, but my sisters old boyfriend in the late 60's had a Falcon with a 427 in it. Narrowed rear, fatty slicks, tube front end. First, and only car Id been a passenger doing wheel stands in! Fast as hell too!
falconman
Jul 23, 2012 05:26 PM
al_inbancroft
Oct 22, 2008 12:53 AM
zombie1974
Aug 23, 2007 11:46 PM
ralphie
Aug 14, 2006 10:55 AM
dudleyp
Apr 18, 2006 10:55 PM
