Climate Control Blower
Old Feb 26, 2023 | 04:02 PM
TWOB's Avatar
Unhappy Climate Control Blower
I have a 2009 F-150 King Ranch with 5.4L. My blower motor runs continuously. This started about a week ago. I've already changed out the blower motor resistor, which according to my research is the most common problem, but that didn't fix the issue. Anyone else experienced this or have any suggestions on what to look at next. Thanks,
Old Feb 26, 2023 | 04:10 PM
Do you have any idea if it is running at high speed or some other lower speed.
In either case you might start with carefully checking the blower motor switch to make sure it has not overheated and is now sticking in the on position internally..
Old Feb 27, 2023 | 07:27 AM
TWOB's Avatar
Default Blower Motor
It seems to be running somewhere between medium and high. How would I go about checking the switch?
Old Feb 28, 2023 | 09:29 AM
TWOB's Avatar
Old Feb 28, 2023 | 10:24 AM
You could try checking the power and ground at BOTH, the resistor and at the motor itself.
The other way is a little more work and it would require removing some of the dash covering to gain access to the switch.
Not knowing your level of expertise , you might consider having a shop do this.
There were problems in the past due to the heavy demand for power for the blower motor that caused the blower switch assy to overheat and self destruct
Msmommi228
Jun 5, 2021 10:06 PM
Kyler Walker
Sep 23, 2017 12:30 PM
Big-G
Jan 11, 2016 11:30 AM
dwcanby
Jun 29, 2010 07:12 PM
hoss1124
Dec 25, 2008 11:16 AM
