AX4N transmission stuck in 2nd
Old May 14, 2024 | 02:13 AM
egleye58's Avatar
Default AX4N transmission stuck in 2nd
I have a 1996 Mercury Sable, 3.0 Duratec DOHC, AX4N Metric transmission with 76,XXX original miles. Six months ago I dropped the transmission pan, changed the filter, added Lucas Oil 24 oz. Transmission Fix, and MerconV fluid until full. I did not notice much difference in the way the transmission has operated since then. Last week I drove the vehicle 5 miles to a destination in the city. Three hours later driving home the transmission was stuck in second gear. Reverse works and it can be manually shifted from first to second. The Service Engine light is not illuminated. I am not sure what to do next.
Old May 14, 2024 | 10:24 AM
Not all problems will illuminate the check engine lamp.
Might be a good idea to have the vehicle checked for any codes.
Old May 25, 2024 | 07:26 AM
Try for any codes?
Old Jun 12, 2024 | 12:56 PM
egleye58's Avatar
There are no codes.
Old Jun 12, 2024 | 01:10 PM
Suggest you have someone with a capable scan tool to verify shift solenoid condition and function.
Could be solenoid,missing signal, stuck 2-3 shift valve.in valve body.
Good scan tool can eliminate the first 2 items.
Pipersimba1
Nov 21, 2022 02:55 PM
Melanie1964
Feb 18, 2022 09:03 AM
Kevinbaltes
Jan 29, 2022 03:53 AM
Bnetty
Dec 7, 2021 05:53 PM
djangoelgato
Oct 28, 2012 07:27 AM
