column gear shift
Old Nov 3, 2019 | 01:37 PM
Starkenburger's Avatar
Default column gear shift
I have a 1997 Ford Aerostar that I was recently getting prepared for it's annual inspection. When I completed oil change,antifreeze flush wiper blades.
the brake lights would not come on. The van started ok signal +park lights worked fine. The problem was it 's stuck in park. Through searching on line I found that it
could possibly be a brake switch. I ordered one proceeded to replace old one and I still have the gearshift stuck in park. Is there a solenoid that maybe causing the problem?
Old Nov 3, 2019 | 03:32 PM
Checking for power at the fuse, as well as power ‘to and through’ the closed brake lamp switch should be checked.. Sometimes the switch harness would break a wire from flexing. If the break lamps don’t illuminate, the shift solenoid won’t have power either..
Starkenburger
Dec 21, 2019 12:16 PM
Wilson
Feb 15, 2017 05:22 PM
benb81
Jan 7, 2017 02:27 AM
dannyg
Aug 14, 2015 10:14 AM
ironhide34
May 16, 2011 09:01 AM
