ECM problem in '98 Expedition Eddie Bauer 4X4
Old Sep 3, 2016 | 06:00 PM
Opsguy's Avatar
Default ECM problem in '98 Expedition Eddie Bauer 4X4
My '98 Expedition (5.4l, 4X4) has started a new problem on starting the engine. The key must be turned on, then immediately off, then back on to start the truck. If it is started with only one turn-on, ALL the warning lights flash and the truck runs very rough, to the point of almost dying. Starting the truck with two "turn-ons", it runs just fine with no lights flashing and everything working normally. Any ideas what may be causing this? I suspect some sort of fault in the computer module on the truck, but I am just guessing. Any similar experience you may have had and a solution to the glitch will be appreciated! Thanks.
Old Sep 4, 2016 | 02:08 PM
It might be a good to confirm that the ign switch on the lower column is making good contact when first turned on.
Many of the circuits operate a such a low voltage any water intrusion at the PCM (computer) plugs could possibly be causing the problem. Check them all for any moisture /corrosion.
Old Sep 4, 2016 | 06:15 PM
Opsguy's Avatar
Default ECM problem in '98 Expedition Eddue Bauer 4X4
Thanks, Hanky. That will be a great place to start looking for the problem. I guess the ignition switch could be wearing out - the truck is 18 years old! It just seems odd that it always works fine on the second switch turn on. It never takes more than that!
tylrhanson24
Apr 14, 2011 03:58 PM
BK1997EB
Apr 13, 2008 09:00 PM
BK1997EB
Apr 13, 2008 08:59 PM
FordExpy03
Apr 2, 2008 04:13 PM
MikeDesire
Dec 23, 2005 02:20 PM
