Mercury died
Old Aug 30, 2022 | 06:46 AM
JB22's Avatar
Default Mercury died
While driving my engine just died. I still had lights and dash lights. Engine would not restart. I coasted to a safe spot. The headlights shut off, then all dash lights and security light came on. Engine would not start. No starter sound. The security system would not allow me to restart. Dash lights flashing. About one month prior, a similar incident occurred after I parked and came back to restart. A website I found suggested I turn the key to on and wait ten minutes, then turn off the key and wait 20 seconds, then try to start. If nothing happened to repeat the procedure three times. After the third attempt all dash lights went out and the engine started. All was good until now.
Old Aug 30, 2022 | 11:53 AM
raski's Avatar
I would start by removing and cleaning of the battery connections and all grounds. There are many grounds located on the engine block, fenders and inside behind kick panels. "Looks" ok isn't good enough. Remove and clean is what should be done first.
Liv Rose
Jul 6, 2021 09:35 AM
18pharris@gmail.com
Feb 1, 2021 05:27 AM
Shovelhead
May 23, 2020 10:23 AM
Amalia Bailey
Aug 15, 2018 04:46 PM
donbola
Jan 21, 2018 01:18 PM
