Owner
Old Mar 1, 2018 | 09:30 AM
Delveelynch's Avatar
Default Owner
1996 Ford F2 50 TPS has 5volts when Accelerator is depressed voltage decreases is this a bad TPS.
Old Mar 1, 2018 | 11:31 AM
Need to know,
where are you measuring that voltage and why are you checking it?
The 5 volts is a reference voltage from the PCM, But don't know where you are taking the reading. There are 3 terminals at the TPS. One should be the 5 volts coming from the PCM, one is a ground and one is the signal to the PCM.
esc92
Apr 22, 2016 10:43 AM
BIG HVM
Nov 10, 2015 04:21 PM
yawgom
Feb 3, 2006 02:51 AM
crazycrak
Sep 26, 2005 06:22 PM
Fis Teck
Jun 7, 2005 12:50 AM
