P0340 and P0345 codes
Old Dec 27, 2023 | 01:08 PM
twhite65's Avatar
Default P0340 and P0345 codes
Hello! I have performed a complete timing job on my 2010 Fordf150, 5.4L 3v engine, 170k miles. Dropped oil pan and cleaned it. Replaced timing chains, tensioners, guides, and crank sprocket with Cloyes timing kit, replaced Cam phasers with new Ford phasers. Replaced vvt solenoids, cam position sensors, coil packs, new Melling 360 high volume oil pump, (oil pressure is great) 5w30 oil and Motocraft filter. After doing this, I crank the motor and get codes P0340 and P0345 (camshaft position sensor on each side. Engine starts, runs for a bit but real rough idle, then dies. I thought I did something wrong, so I did the timing again step by step. I still get the same codes after the second time around. I have good voltage to cam position sensors, and good continuity to PCM. I know I put timing chains on correctly matching the timing marks etc….I did remove camshafts and after putting them back in and putting timing parts in, then installed roller followers back in. But I still get these two codes, and the codes come back after I clear them, and engine runs rough. Not sure why. Driving me crazy!! Anyone have any ideas or suggestions? Terry.
Old Dec 27, 2023 | 01:59 PM
I know you just wanted to do all this work, but if you had the problem before the work , suggest you check the cam sensor on the driver's side. Something is not right there. Either the wiring /connections or the sensor itself.
Old Dec 27, 2023 | 02:14 PM
twhite65's Avatar
Thank you hanky for your reply. I didn't have these codes until after the timing job. The original codes were P0021 and P0022 so I replaced VVT solenoids and still had code P0021, so I decided on timing job. It was a lot of work for sure, and now I am left with this issue.
Old Dec 27, 2023 | 03:46 PM
If it was not there before the work, just recheck your work. I believe it is involving that cam, sensor or wiring.
Möęčãnic
Dec 10, 2022 11:27 AM
smi889
Jul 13, 2021 05:50 AM
Luke Jeffrey
Aug 28, 2014 03:29 AM
jrbayler
Jun 17, 2014 02:22 PM
Donald97
Aug 24, 2011 03:29 AM
