Starter engages while running
Old Aug 24, 2024 | 06:17 PM
expidetion99's Avatar
Default Starter engages while running
I have a 99 Expedition and it just started engaging the starter while its running. I replaced the starter solenoid and a flasher relay. Took the starter switch off and put it back on. I still hear noise from the starter solenoid like a circuit spazzing out. And with the key on the starter kicks in quick and slaps the flywheel after about 7 minutes. Do I need a new switch? Very strange..
Old Aug 25, 2024 | 12:09 PM
Do you know if the windshield on your vehicle ever leaked ? If there is a lot of rust over the area of the CJB (Central Junction Box) interior fuse panel corrosion there could possibly explain what might be happening. Problem from corrosion in that area caused quite a few unexplained things.
skrtjones
May 14, 2020 12:25 AM
jt13
10
Aug 7, 2018 05:41 PM
mlurockuv1
11
Sep 8, 2013 10:29 PM
dman
Jan 19, 2011 03:28 AM
jsaville40
May 19, 2010 08:30 PM
